ericsf avatar image
ericsf asked
Could not get the remote control working with Phoenix Inverter Compact 24/2000
I want to control my Phoenix Inverter Compact 24/2000 from the remote switch.
The DS switches are configured with factory settings:
- DS1 is off
- DS2 is on
which should make operable the "on-off/charger only" switch.
However when I short the the right terminal with the middle terminal in 'remote swicth' connector, the output alternating current is still there.
Did someone face (and solve!) a similar issue ?
thank you!
Phoenix Inverter
