ronald-v-i avatar image
ronald-v-i asked
SmartShunt FW update got stuck at 2% with D26 error code.
Brand new SmartShunt 500A/50mV. Most things seems to work with the VictronConnect app on my LG phone. Except when I go to the settings menu, it tells me I must update before I can do settings. When I update it always fails at 2%. After couple of seconds it gives me a D26 error code. I need to power cycle (via the fuse) the PowerShunt to get Bluetooth connection back. I tried a 4 inch and 2 feet distance between my phone and the SmartShunt, it all got stuck at 2%. I tried bluetooth unpairing and resetting my bluetooth pin code. Nothing seems to work.
Anyone any idea what it can be? (before I send it back).
Thanks
Ronald
P.S. I'm already using my VictronConnect app with my SmartSolar SCC. I have done multiple successful firmware updates with that app for that device.
SmartShuntfirmware update
7 comments
Hi @Ronald v. I.
Can you please make a service report of the update and post that in a comment here? The procedure is described here: https://ve3.nl/VictronConnect_How-to-create-a-VictronConnect-Service-Report
Kind regards,
Thiemo van Engelen
ronald-v-i avatar image ronald-v-i Thiemo van Engelen (Victron Energy staff) ♦ commented ·
@Thiemo van Engelen (Victron Energy staff) ,
Thanks for your response. Attached the requested log made after the problem occured. Hope you can help me.
VictronConnect_report.log
Thanks
Ronald
Thiemo van Engelen (Victron Energy staff) avatar image Thiemo van Engelen (Victron Energy staff) ♦ ronald-v-i commented ·
Hi @Ronald v. I.
We will contact you via email.
Kind regards,
Thiemo van Engelen
@Thiemo van Engelen (Victron Energy staff) , not sure what went wrong but can you please reconnect me with the support engineer. Thanks
Hi @Ronald v. I.
The support engineer is on holiday this week. I expect that he will contact you beginning of next week.
Kind regards,
Thiemo van Engelen
matt-tolman avatar image matt-tolman commented ·
Do you possibly have an update to what this issue is and what the solution is? I am having the same problem.
Thanks in advance,
Matt
ian-lavin avatar image ian-lavin commented ·
Do you possibly have an update to what this issue is and what the solution is? I am ALSO having the same problem.
