marcp72 avatar image
marcp72 asked
Multiplus II AC1 in relay will not close to allow grid power in
Hi, when connecting to the grid I can see from Victron Connect that the AC1 in relay/gate is open and will not allow grid power in. Is there a setting in Victron connect to cure this?
Multiplus-IImultiplus ve.busgrid
Alexandra avatar image
Alexandra answered ·
@marcp72
Dp you have a gx device connected? Under devices and multi you can see what is happening there.
But yes uncheck UPSfunction and you should be all set.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
