jdpete avatar image
VE direct module won't green light
I have VE direct module connected to the Victron 150/70 controller but it will never go to green light from blue flashing. I setup my own gateway using The Things Indoor LoRaWAN device. Once it was claimed it showed it as active and connected but when I go to VRM portal installation of VE module it will not find the device when I type in the portal ID. Any suggestions?
VRM
jdpete avatar image
jdpete answered ·
I read in another post that if you disconnect the cable from the MPPT the ve direct module should flash yellow if it is connecting to the gateway. Mine is not. The Things Gateway I setup is connected. Could the ve module potentially be defective? Any suggestions would be appreciated!
Daniël van de Giessen avatar image
Daniël van de Giessen answered ·
The module will blink blue while it is connecting to the network. It will only blink yellow of green once it has connected. So it's correct you're not seeing it blink yellow when it is still connecting, it will continue blinking blue.
A few things you can check:
  • Is your The Things Gateway connected to the appropriate cluster for your region? EU868 modules should use the eu1 cluster, US915 modules should use the nam1 cluster, and AU915 modules should use the au1 cluster.
  • Since you are running your own gateway, you can look at the traffic from the gateway to check if it is receiving the messages broadcasted from your module. To do so, log in to the appropriate cluster in the TTN Console, go to your gateway, and in the Live Data view look for messages from your device (the DevEUI / Entity ID will match the VRM Portal ID). If you're not seeing data from your module there, your gateway may not be set up correctly.
