squelch avatar image
VE MP Parrallel (3x1Phase) , Error 17
Hi Team,
See below system components:
a) Multiplus 48/5000/70 : 3 units , FW: 430
b) Bluesolar CC MPPT 150/85 (VE Can port) : 4 units , FW: 2.05
c) BYD B-Box L 2.5 : 11 units , FW: 4.17
d) CCGX : 1 unit , FW: 2.22
Problem:
Our system always shutsdown everytime the patch cable from the end of paralleled inverter connects to VE Bus of CCGX or if (CCGX reads the inverter system shutsoff after 30 secs). We tried different approach on how to start up the system with out tripping it off, but still we have no definite pattern on what was causing it. What we do temporarily is disconnect the patch cable between MP and CCGX just to run the system.
You can see on the screen cap i attached the LED indicator of Master & the slaves.
for Slaves : LED blinks alternately between Inverter On and Bulk, Then steady light for Absorption and Float.
Any thoughts on this ?
Let me know if you need any other details.
CCGX Color Controlparallel
Martijn Coster (Victron Energy Staff) avatar image
Martijn Coster (Victron Energy Staff) answered ·
@squelch Did read this thread. I agree with @Guy Stewart (Victron Energy Staff) that it sounds like the VEBus interface on the CCGX is not working. You should have this replaced free of charge. You can contact the dealer you bought it from or contact our repair department: repairs@victronenergy.com
best regards
Martijn Coster - Victron Energy
@Martijn Coster (Victron Energy Staff) & @Guy Stewart (Victron Energy Staff),
You too are both correct, i replaced yesterday the problematic CCGX unit with the new one and it already works. We will contact our distributor to arrange the replacement of the defective unit.
Ty
Paul B avatar image
Paul B answered ·
long shot. try changing the CCGX to demo mode then back to normal.
maybe this may cause a re detect and may solve the issue. ?????
Paul B avatar image
Paul B answered ·
@Paul B,
Can't do online update. Because site is situated on an island. Just pull my self there a couple of hours ago. But have to be back by next week if CCGX needs to be replace.
ossi avatar image
ossi answered ·
Dear Earl,
Try remving your End terminations on the VEBus if you have put in.
Terminations are only used with VECan.
BR
Oliver
@Oliver,
I had not put on end terminators on the VEBUS.
Hi
Did you check the VEBus RJ45 connection cables with RJ-45 Tester or with a Multi-meter (conductivity)?
replace the used cables for new and pre-crimped ones?
BR
squelch answered ·
@Boekel, @Paul B
Update from my current FW MP update from 431 to 433, CCGX is not detecting the presence of Multi from it's GUI.
But, system is now energize.
any thoughts on this?
ty
8 comments
Id give it overnight first, then I’d be starting again from a programming side.
Check each unit individually, does it connect? does it show up.
And expand from there, that should help to identify the exact point of failure, and more specific troubleshooting advice.
squelch avatar image squelch Guy Stewart (Victron Community Manager) ♦♦ ·
Thanks, @Guy Stewart (Victron Energy Staff),
I'll work on your recommendation.
1) Tried repogramming individual MP units to standalone mode and still did not show up.
2) Repgrogrammed it again to 3xparrallel units as a 1 phase, still no show.
If you are confident with your cables, it sounds like a fault.
Maybe replacement, I have created a ticket for Victron Service Dept. They should get in touch with you.
Fault on the CCGX?
Yes, more likely a fault on the CCGX.
If you have tried with different cables, and three different multis that have been returned to their default out of the box settings.
Then that leaves the CCGX.
Whom do i should contact with for this faulty CCGX unit?
The place of purchase should be contacted for warranty replacement claims,
Please read this - https://www.victronenergy.com/support
Paul B avatar image
Paul B answered ·
Also try upgrading the FW to 433 for the all the MPs and the firmware on the CCGX to 2.23
also check the suggestion made by Boekel
you can check what the lights mean in the victron tool kit app, downl;oad this and install it and see if that gives you any clues
Thanks, Paul.
I'll do the 433 FW update of the MP. For the CCGX 2.23 FW can't seem to see it on the victron professional site? would you mind sharing the file.
ty
boekel avatar image
boekel answered ·
Probably not the cause, but did you check in remote console (devices: Multi) if you can manually turn the inverters 'on'? (just to exclude this possibility)
(edit...as you have the CCGX you don't need remote console but can check directly on the panel...)
Hi Boekel,
Never tried that. But i just recently upgraded my MP FW to 431 about 15 hrs ago as i type. And MP isn't appearing on the CCGX GUI. I'll try to upgrade it to 433 and see what happens.
