matthias-roetzer avatar image
matthias-roetzer asked
Victron Connect does not find devices
Victron Connect does not find the attached devices on one laptop but on another it does. In earlier times this was fine on both laptops but don't have a clue when the behaviour changed.
Octo GX is running 2.80~21
Both laptops are in the same wifi! The screenshots are taken only a minute after each other!
1st laptop: not working on Win10
2nd laptop: working fine on Win7
Any idea to resolve this is very much appreciated!
Best regards,
Matthias
VictronConnect
bocas-uflex avatar image
bocas-uflex answered ·
Maybe You have not properly installed USB drivers...there is a specific instruction here:
https://www.victronenergy.it/support-and-downloads/software
USB drivers installation program for MK2-USB/MK3-USB
matthias-roetzer avatar image matthias-roetzer commented ·
Im connecting via VRM not locally, so USB drivers are no matter.
matthias-roetzer answered ·
Just updated to V5.48, still same issue
Steve Preston avatar image Steve Preston commented ·
I too am not able to find my WIFI enabled CerboGX via its IP address, which is connected to my network, in the local tab in 5.48 in Windows 10. It is accessible via VRM.
Also, when I connected to my Smartshunt through VRM, I was informed it needed a firmware update which it proceeded to do. A message stated to NOT leave the application and the update stayed at 0% for a long time. All of my Android devices reported that the Smartshunt has updated to 4.08 but the Windows application was stuck at 0%. Since it was reported as updated to 4.08, I forced closed the application and reopened it. It found the Smartshunt and all is OK with the Smartshunt.
Steve Preston avatar image Steve Preston Steve Preston commented ·
As of 10:20 P.S.T., I am able to see and access my LAN connected CerboGX.
Issue solved.
Typical fail of humanoid sitting in front of PC :)
Login via user without "full control" will result in VictronConnect not showing devices connected to GX via VEdirect.
