jsheehan avatar image
jsheehan asked
What isolators, fuses, circuit breakers or other products do I need to install my System?
I have recently purchased:
- 2 x 48v Pylontech 3.55kwh Batteries
- Victron Multiplus II 48/5000
- Victron SmartSolar MPPT 150/70
- Victron Cerbo GX
- 6 x LG Neon 2 360w Solar Panels
I am wondering what fuses, isolators, circuit breakers and any other products do I need to fully complete and install my system. Do I need a DC Fuse Disconnector straight after the Batteries? Do I need a Lynx Distributor, if yes, what does it do. It would be awesome if somebody could draw a diagram where each isolator, fuse or circuit breaker goes in my setup. Any help will be much appreciated.
Pylontechfusesisolators
seb71 avatar image
seb71 answered ·
Some things to get you started:
  • Use copper busbars (positive and negative). You will connect your batteries, inverter and charger to these busbars.
  • Use fuses (not circuit breakers) on all positive wires connected to the above busbars.
  • Wire sizes (cross section area) should be chosen based on the maximum current (A) each wire should carry.
  • Fuse size is selected so that it protects the wire: the fuse blows at a current which that wire can still safely carry; but the fuse should not blow at normal current.
  • You must have a battery disconnect (between the battery and the positive busbar). You can use a HRC fuse (in a fuse holder) to do both the job as a battery disconnect and also as a fuse for that wire.
  • You must have a PV array disconnect from the solar charger (and always disconnect the PV array before disconnecting the battery).
  • Use gPV fuses (in fuse holders) on the + and - wires from the PV array to the solar charger.
  • Pre-charge the inverter capacitors before each time you connect it to the battery (or before each time you reconnect the battery to the busbar). You can use a power resistor or an incandescent light bulb for this.
jsheehan avatar image jsheehan commented ·
Does my wiring Diagram for my system Make any sense?
Alex Rodgers avatar image
Alex Rodgers answered ·
Hi
This book from Victron will offer some insight.
https://www.victronenergy.com/upload/documents/Wiring-Unlimited-EN.pdf
But would also suggest you get advice from a competent electrician and solar installer on your particular setup.
Good luck.
Victron Pylontech battery compatibility guide
Fuses & fuse holders Product Page.
