elektrotechco avatar image
elektrotechco asked
Different charging sources - simplest separation way
I have a question about the currently used methods - what is the best and optimal method of separating power sources. I have on yacht following set of charging devices:
1.2x alternator 12V 80A on engine
2. Victron Multiplus 12 | 2000 | 80-50A
3. Wind/solar charger - output max 40A (other manufacturer)
Then I have 3 battery banks:
A. 1x 12V 120Ah standard battery - starting batt.
B. 2x 12V AGM 110Ah (Victron) - bowthruster and winch
C. 3x 12V AGM 110Ah (Victron) - house batt.
Please advise how is the optimal solution for connecting this different charging sources. I think to use three AgroFET 100-3 or 200-3 separators for each charging source. But maybe experienced users can advice more optimal method which control the charging current from different sources?
Do you think it is advisable to also separate the alternators and treat them as two separate power sources.
Regards,
battery chargingcurrent limit
