enodev avatar image
enodev asked
Multiplus 12/1600/70 negative AC Out power consumption
Hi guys,
one more puzzling question about my new Multiplus 12/1600/70.
if you look closely at the Victron Connect screenshot below, the AC out is drawing -4W, that is minus four wats. This is without any AC load. If I turn on the coffee maker, the Victron Connect correctly reports around 1000W, that is plus thousand watts.
But sitting idle, there is minus 4 watts.
that sounds like nonsense, right? Firmware 485. Possibly related to my other question here https://community.victronenergy.com/questions/101904/aes-search-mode-mode-not-starting-in-low-watt-sett.html....
Any idea what is going on? How could this even happen?
thanks
Martin
multiplus ve.bus
Just upgraded mine to latest firmware, introduced the same issue and stopped it going into low power mode.
kevgermany avatar image kevgermany ♦♦ kevgermany ♦♦ commented ·
Thinking more about this, I think the report is showing the inverter internal consumption as an AC load.
pmikep avatar image pmikep commented ·
I reported similar on January 28, 2021. (Didn't my post show up when you searched for this issue before posting?)
Anyway, it appears to be noise from an internal sensor picking up current from the inverter. (Eddy currents? Radiated?)
I recently did some more testing on this, and recorded a bunch of video. I'll plan to edit it and post a link here and in my original Report, FWIW.
But it might not be worth anything because from what I can tell, it appears to be hardware related. Meaning that it would take a hardware revision to fix properly. But I expect that Victron is done revising the Mulitplus now that the Mulitplus II is in production.
(In my original Report, where I didn't realize that 120 VAC was passing through to L1 even when in "Charger Only", I suggested that this problem could fixed/hidden by software. But I was wrong.)
Mike Dorsett avatar image
Mike Dorsett answered ·
At low power levels, you will have a capacative current flowing in the AC circuit:this will be causing a small offset in the AC /Dc converter feeding the ADC for the AC current sensing.This will modify the device's zero setting value. With a large load, this small offset is swamped by the main resistive current flowing in the coffee maker's heater.If you disconnect the AC out cable from the inverter, you should see the no load ac power go to zero.
Don't worry about this small offset.
enodev avatar image enodev commented ·
I see -4W all the time when there is no load, even when the cables are disconnected, that is what was puzzling, but sound like your answer may explain it. Thanks a lot for your time!
