Macedon Moldovan avatar image
Macedon Moldovan asked
File is not a SQLite database.
Hello. The size of the data file downloaded from Color Control SD card is higher than 64Mb and I used Zip to compress it. When I uploaded the zip fileon Victron Energy platform I received the following error message: "Error. Failed to process data file. File is not a SQLite databas." Could you please help me with this problem?
Thank you!
VRM
5 comments
@Macedon Moldovan
Try uploading without the zipping.
Macedon Moldovan avatar image Macedon Moldovan commented ·
Files larger than 60 Mb cannot be directly uploaded on VRM portal.
Alexandra avatar image Alexandra ♦ Macedon Moldovan commented ·
I totally forgot about the limit. How are you zipping it? I used z-zip the last time.
If not, and this option it will take alot of time, but you would need to let the gx upload it
Macedon Moldovan avatar image Macedon Moldovan Alexandra ♦ commented ·
I used z-zip. But not this was the problem.
The file downloaded from the SD card is named "vrmlogger-backlog.sqlite3". After I removed the number 3 from file extension and I Zip it again I could upload the archive on the VRM portal. The data is visible now on the portal.
Excellent. Well glad there was the desired ending.
Alexandra answered ·
@Macedon Moldovan
If you are wanting to analyse the data locally you cannalso use victron connect.
