Can the load disconnect on the VE BMS manage (2) Solid Switches?
I would say yes. The data sheet (https://www.victronenergy.com/upload/documents/Datasheet-SolidSwitch-104-EN.pdf) shows that the input to turn on the switch is 30uA and the load disconnect on the VE.Bus BMS can handle 2 amps:
Load Disconnect The Load Disconnect output is normally high and becomes free floating in case of imminent cell under voltage. Maximum current: 2A.
28 People are following this question.
