I just thought to report this here, it was recording history for a while now for some time it's only showing me the current day I'm on. Anything I can do?
Using latest update on iphone. Unit seems to be working well otherwise now.
I am experiencing something different but with a similar outcome in my history usage.
after current day, all previous days display fixed (but incorrect data). When I reset history, each day continues to show the exact same data as before the reset (repopulating each column with the passing of each new day). The only correct column is current day.
more details here:
https://community.victronenergy.com/questions/102784/error-with-history-tab-in-connect-app.html
Hi, I checked; there was a bug indeed - and which is solved in Inverter RS firmware version v1.05. Which is already available on the VRM online update system, as well as for manual download & install on https://professional.victronenergy.com.
VictronConnect does not yet have it, the next official VictronConnect release will.
38 People are following this question.
