pmolettiere avatar image
pmolettiere asked
ve.bus BMS terminal trouble
The charge disconnect / load disconnect terminal row on the ve.bus BMS seems super janky to me. Even using ferrules, the release tabs are super hard to press since they're nearly entirely covered by the plastic cover. It's very easy to get the tabs to latch under other components, like the nearby LEDs, which prevents them from popping back up and holding the inserted ferrule firmly, resulting in intermittent loss of connection. On charge or load disconnect, this can completely disable loads or charging.
Does anyone have tips on using this connector in a way that's reliable? Is there a special tool for inserting ferrules? What am I missing here?
Why did Victron cheap out on this connector, rather than use the normal screw terminal adapter blocks on pretty much every other product?
BMS
Yes, this connectors are tricky sometimes.
I use them without ferrules and this is working pretty good.
drlbradley avatar image
drlbradley answered ·
same here - I removed the ferrules and used a watchmakers(v small) screwdriver to depress the tabs
pmolettiere answered ·
Answering my own question here, in the hope that this may help someone else down the line. Ferrules don't slide into the BMS port very well, and I'm loathe to just jam twisted wire up into them. I ended up buying special crimp on pin connectors via Amazon, which are both longer than ferrules, and a tiny bit narrower, and that resolved my issue. PKYS.com sells them, and you can find them on Amazon.
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
