jmz506 avatar image
jmz506 asked
Victron Phoenix 24/1200 inverter shut down voltage
I am considering buying a Victron Phoenix 24/1200 PIN241220500. The datasheet gives some specifications for the input voltage:
  • input voltage range: 18.4 to 34
  • low battery alarm 21.8
  • low battery shutdown 18.6
  • low battery restart 21.8
I would like to use my battery down to 19v. Will this work? What will happen at 21.8v?
Also, can you tell by the part number if I will get a VE Direct interface?
Phoenix Inverter
Paul B avatar image
Paul B answered ·
Yes it will work
All the setting are adjustable
at the default warning setting of 21.8v you will get a blinking light
yes a ve direct output comes with the unit. but you will still need a interface cable etc
