jan-schober avatar image
jan-schober asked
Phoenix and Multiplus sharing the same Neutral (Floating)
In my setup I'm using a Phoenix 24/375 inverter and a 24/3000 multiplus inverter/charger.
Can I share the N-lines of both inverters in my breaker box? (it's for an RV)
I would say: when not hooked up to shore power, the Multiplus connects Neutral to earth, then it should be no problem, but when the RV is hooked up, the neutral is disconnected from earth, and I have two floating suppliers.
Drawing:
- 1st: The red one is the main switch
- 2nd: The RCD's are combined double pole 16A breakers,
- 3rd: followed by specific equipment breakers
MultiPlus Quattro Inverter ChargerPhoenix Inverter
