tas-cpa avatar image
tas-cpa asked
Multi Plus II Switch Pulled Apart
Anybody have pictures or a diagram of the actual interior layout of this switch? Pulled the board off the back of the switch when holding the wire aside to mount the unit. Now have a PCB? board, a metal rocker and maybe one small unidentified plastic piece.
switch
marekp avatar image
marekp answered ·
This orange piece of plastic goes into the rectangular tube with the spring inside. The sharp tip sticking outwards.
On the center contact on the PCB place the metal rocker and join the plastic housing with the PCB.
The are only two ways the rocker goes on. One of them is correct.
Probably bottom of the "V" should go towards the PCB.
tas-cpa avatar image tas-cpa commented ·
THANK YOU!!! Yes, I am yelling.
Kevin Windrem avatar image
Kevin Windrem answered ·
If all the pieces are accounted for and nothing is broken, it may be possible to reassemble the switch.
That is what I'm hoping for, but hoping someone knows what the actual pieces should be.
