shaneyake avatar image
shaneyake asked
VRM not showing correct export with AC-PV inverter
Currently my dashboard is only talking into account Inverter_to_AC-IN kwh numbers for the To Grid value, how do I also get it to add the AC-OUT to AC-IN kwh numbers? I have another inverter on the output of the multiplus but I do not have a meter on the inverter nor is it a compatible PV-Inverter.
If I manually added the Inverter to AC-IN and AC-OUT to AC-IN, I get the same kwh as my utility meter.
Thanks
VRM
Some more information about your system please and maybe some pictures/screenshots.
shaneyake avatar image shaneyake commented ·
VRM History:
Data from utility meter for the same period:
