mrhappy avatar image
Node-red dashboard access on Venus OS Large 2.80-11/20
I have flashed the large 2.80-11-20 file to an SD-card, put it into a Raspberry Pi 3 B+, enabled node-red in console, followed the instructions on how to install the dashboard in palette and made some test nodes. VRM portal all working fine, but when I want to access the node-red dashboard by changing "/dashboard" to "/proxy" I don't get any node-red button to click, it jumps to "installation overview".
What am I doing wrongo?
VRMNode-RED
Teun Lassche avatar image
Teun Lassche answered ·
You are missing the trailing slash: /proxy/
mrhappy answered ·
Oh, dang. Thank you!, that takes me to the node-red editor. But how do I access the dashboard? I do type in:
https://(my installation number)-nodered.proxyrelay3.victronenergy.com/ui
but I get "not authorized, the tunnel connection to the installation was lost, or the session expired, go back to VRM and retry."
I can access it locally via (raspi ip):1880/ui
Thank you for engaging my beginner questions :)
Ok. Got it working. Similar noob mistake as the missing trailing slash. I was reading the instructions too literally. My node-red connection goes to "proxyrelay1" and I copy-pasted the line from the instructions that had "proxyrelay3" instead, thinking I could use that with my installation number. Just adding "/ui" to my editor url did the trick.
Fantastic that you guys have enabled this, I now see massive possibilities opening to control and supervise my installation remotely. I assure you, you will sell more of your gear because of it :)
