Take the units front cover off and advise the number on the chip it will start with 19 or 26 if its a 220v unit,
the firmware you are trying to install the first 4 numbers must match
I think the upload firmware you want is 2620486 but the again the first 4 numbers must match
Hi Paul,
Kindly see attached photos.
All of them are suitable for your Multi. I would recommend to use the latest one (486).
You have some kind of connection problem. Did you follow the instructions?
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
Can you connect to the Multi with VE.config?
I can connect with Multi with VE.config.
Some case occurred while I am on the step 2 of the FW update (Turning On the Multiplus)
1. The Multi does not show LED signal and the connection error appeared in the VE Flash
2. The Multi's LED light are all on and the connection error appeared in the VE Flash
All connection error appears after step 2 (turning on the Multiplus)
Also, I tried updating using VictronConnect (OTG to MK3) using Android phone and it said that it is only applicable for Multi with 415 FW or above.
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
51 People are following this question.
