Looking to connect Garnet 710 SeeLevel sender to the cerbo GX. Cerbo only accepts resistive senders. Anyone have a fix that allows me to use the Garnet capacitive sender?
The Cerbo itself is only compatible with resistive sensors. The GX tank 140 will maybe work with your sensor.
https://www.victronenergy.com/panel-systems-remote-monitoring/gx-tank-140
26 People are following this question.
