Am about to wire up the camper auxiliary battery, and wondering what's the best charge parameters to use without causing damage to the battery.
Look at the specifications of your battery from its manufacturer. Program that into the mppt.
Alexandra I was wondering do i enter the same for the mppt and the dc to dc as dont want 30 plus 15amps pumping into the battery ?
The amps are up to you to set based on the max the battery can take and balance that against the max the the DC to DC is doing with the added mppt. like 30 plus 15 amps if the battery is well down then you have to allow for average draw as well
otherwise change the battery to Lithium and then the battery charge limit is not overly affected/ as lithium can usually take a charge rate equal to there load output, usually and also depending on brand specs, anyway the limit is much higher than L/A batteries
27 People are following this question.
