Does it matter how I wire my 3 LifePO4 batteries to a Lynx Power In/Distributor as far as the order of positive/negative connections of each battery from left to right on the Lynx?
In other words, should the positive connections be connected to the busbars in reverse order of the negative connections to reduce imbalanced current draw of the paralleled batteries?
Examples that have caused my confusion:
From 'Wiring Unlimited'
![1629170734463.png](/storage/attachments/22891-1629170734463.png)
vs.
From Lynx Power In Manual - Design
If I wire like the 2nd reference picture (from the Lynx In Manual: system design) than the current flow would go through the furthest right battery more than the furthest left battery, hence why 'Wiring Unlimited' (first picture) recommends having the flow go diagonally through the battery bank. So shouldn't the second picture show negative/positive cables connected in reverse order of each other? So confused.....
Max amps through my entire system will be 300amps
Thank you in advance!
