ejrossouw avatar image
Smartsolar firmware 1.59 update
I saw the latest MPPT firmware was released stating it applies to all the models, however noticed the Smartsolar 75/15 does not get updated using the latest version of IOS VictronConnect 5.47 or the Android version and remains on 1.56. Can this point in relation to "all models" be clarified please? The larger models updated in line with earlier releases and the documentation guides.
MPPT Controllersfirmware update
v1.59 is not jet included in the current official VictronConnect version.
It is included in the latest beta version.
https://www.victronenergy.com/live/victronconnect:beta
If you want to install v1.59 on your devices you have to download the beta of VictronConnect or the FW files from Victron Professional
https://professional.victronenergy.com/downloads/firmware/
(free account needed)
If you have a GX device you maybe can also update the MPPT via the VRM portal.
Via the VRM portal are new FW version available faster.
https://www.victronenergy.com/live/vrm_portal:remote-firmware-update
ejrossouw answered ·
Thank you. That explains why the GX connected devices all updated and not VictronConnect.
li-tech avatar image
li-tech answered ·
I have just upgraded a SmartSolar 100/20 that already had firmware BT2.25 & v1.56.
Yesterday the controller wanted to upgrade from v1.56 to latest and afterwards the Load Turned Off and tried any setting on Load Output but still shows as Off with a 75% fully charged 12V battery and two 200W solar panels. 0V on Load Output.
Was working fine before the update as downloaded history etc.
The controller was still showing the solar panels charging.
Can I reload the firmware or revert back to 1.56?
