billknny avatar image
billknny asked
VRM Missing Data and Widgets?
The graph of SOC, arguably the single most important piece of data, in my VRM has disappeared, and the widget to display it has also gone walkabout, although the other data widgets from the BMV are available.
Data appears normal on the local CERBO system, all present and behaving normally. All of the other data presented in the VRM looks correct, although I haven't yet had the chance to do a full audit. There are a few other data that also disappeared, but the SOC is of prime concern to me.
How do I get my SOC data back?
VRMSOC
billknny avatar image billknny commented ·
An update after further investigating:
Other data has also disappeared. Specifically "Battery Temperature" as reported by the Multiplus. Same deal, the graph has disappeared from the "Advanced" page and the widget has disappeared from the list, so can not no longer be selected. Same exact symptoms as the SOC above, and again, the data is available locally on the CERBO as before.
These are both really important pieces of data to me, how can they have disappeared from the VRM Portal and no longer be accessible? Is it even remotely possible I am the only one who is seeing this?
Teun Lassche avatar image
Teun Lassche answered ·
Hi all!
I've confirmed this issue and released a fix! Sorry for the inconvenience
trip-tracks avatar image
trip-tracks answered ·
Yes, I can confirm there appears to be a VRM issue here.
I have some sites with SOC widget missing (where they were present previously), while other sites are ok.
@mvader (Victron Energy), are you aware of this?
Thanks for reporting, looking into it.
Bas Rijniersce avatar image
Bas Rijniersce answered ·
Confirming the issue, in my case the MPPT Yield graphs are missing
Bas
billknny answered ·
The widgets are back! Thanks Victron for the quick fix!!
Some strange figures in the calculations - DC power does not reflect volts x amps, AC Loads does not reflect volts x amps
The watts add up for the system but not correct - the current is correct.
This other system is way out showing 37.4A....
glenmc avatar image
glenmc answered ·
This issue appears to have returned, as I have the same issue.
Widgets not displaying graphs, also when you add a widget and go from advanced to dashboard the new widget disappears. The only widget that displays correctly is MPPT State.
System was displaying correctly unit 5-5-2022, system consists of MPPT's and cerbo
