phil-fouracre avatar image
phil-fouracre asked
PWM Controller
I think I’m slightly out of my depth looking through some of the discussions on here!!
I converted a camper a while ago and then decided to fit a ‘simple’ solar system
I installed one 100w panel and a 20amp Victron PWM controller which has worked well, but was planning to ‘improve’ the performance
I’ve now got a second identical panel to add, but, am slightly confused as I’ve been told that I can wire it in series or parallel!
I was told that the controller would allow this, but, is this correct if I wire in series and then have 24volts to it?
Any pointers would be very helpful
Many thanks
Phil
charge controller compatibility
From the manual:
With a PWM charge controller the panel voltage have to match the battery voltage.
If you switch to a MPPT charger you can wire the panels in series and benefit from a higher efficiency (up to 30% more).
