battery-boy avatar image
battery-boy asked
How to select the correct Battery System in ESS Assistant for BYD BMU LVL 15.4
I'm in the process of setting up a 3-phase system utilising 3 x Quattro 15kVA, Cerbo GX with touch 50 GX interface. The batteries used are 4 x BYD LVL 15.4 modules. The BMU connects to the BMS Can interface connection, using the Type A Cat5 cable, with a termination plug.
I'm at the point of setting up the ESS Assistant within VE Configure 3 where asked to specify the Battery System.victron-qs-002.jpg
The two options as I see it are the with two-signal or "with other type BMS".
Where in Victron literature can an answer be found, as the technical data on the LVL is scant.
ESSBMSBYD
JohnC avatar image
JohnC answered ·
battery-boy answered ·
@JohnC that's exactly what I was looking for. Thanks for taking the time to point me in the right direction. Power of community is great!
Cheers
