drmi avatar image
drmi asked
two ESS-systems grid-parallel
I have two ESS-systems parallel connected on a unique ACin:
ESS1: 3x Multiplus 48/5000, OPZS 1920 Ah, Color Control, EM24 (on grid root)
ESS2: 3x Multiplus 48/5000, BYD Pro 12.8, Color Control, EM24 (on grid root)
The battery of ESS2 is discharged faster than the battery of ESS1 - as I see.
Which settings (f.i. setpoint,..) should be done to get a "optimal" situation ?
Regards Michael
ESSBYD
Paul B avatar image
Paul B answered ·
Realy cant help much here as we dont know the loads on each system or the total setup.
so best you can do is trial this and that setting and fine tune things until you get it closer
if the loads are the same then I would be looking at the battery type/ or size comparison. and go from there
