abraxas avatar image
abraxas asked
Multiplus charger - Alert "high DC ripple"
When I charge a 200Ah lithium battery with a Multiplus 12/500, after a while the charger switches off and the "high DC ripple" alert appears. Could not charge it fully. I took the battery and the Multiplus out of the electrical system to connect them directly to each other, but the problem persists ...
So I imagine the error is either from the battery or from the multiplus?
Have you ever run into this problem? What do you think is the cause?
thanks in advance
MultiPlus Quattro Inverter ChargerLithium Battery
What is the cross section area (wire gauge) of the wires between the battery and the inverter?
abraxas avatar image abraxas seb71 commented ·
Hi seb71,
That's a 16mm2 wire (5AWG)
@abraxas
Other than the advice to check out wiring unlimited, i have seen some batteries do this when they are sharged faster than the bms amp rating of the brand. And I have had to open a 'new' battery and tighten down cell links they were loose and caused dc ripple.
Also happens on banks that have undersized or incorrect cabling as seb mentioned.
abraxas answered ·
Hi seb71,
abraxas answered ·
Impossible to do absorption and float phase.
The charger throughout the Bulk phase then goes into alert.
I managed to fully charge the battery (absorption and float) with the orion alternator charger. Which comforts me in the idea that the problem comes from the multiplus.
My two cents, start with the official material: this powerpoint here on top: https://www.google.nl/search?q=dc+ripple+victron&ie=UTF-8&oe=UTF-8&hl=en-nl&client=safari
And then if you want to know all there is to know about wiring: read the wiring unlimited book we have.
lastly, I’m sure also the manual gives advice on dc ripple and its common causes.
have a good weekend!
Jaco Reinecke avatar image
Jaco Reinecke answered ·
Chances are very good that you have unbalanced cells, the forces the BMS to disconnect to protect the bank.
Got that T-shirt.
