Grant Baldock avatar image
Grant Baldock asked
SmartShunt 500A not setting SOC to 100%
Hi all,
I think I need some help understanding why my SOC is not being set to 100%. I have 2x 120AH Lithium batteries installed in my camper. I have the SmartShunt settings as per below with the Battery capacity set at 240ah
I also have a Victron IP22 30A Charger installed.
The Charger is reporting the battery is in Storage phase and has been for almost a week. I also noticed today that it did it's weekly absorption cycle. The SmartShunt is reporting Voltage of 14.13 with a almost constant Current of -0.15A or -0.16A and power of constant -2W. The charger is reporting voltage of 13.89v and Current of 0.0A. I manually set the SOC to 100% last weekend when the charger went into storage mode. Given the current draw the Consumed AH is showing -25.1 Ah and the SOC is 92%.
From my understanding given the settings I have for the shunt the SOC should automatically set to 100% once the voltage is above 13.5, the tail current is less than 2% and this is condition is maintained 3 minutes. Am I wrong? What could be preventing this setting to 100%?
SmartShuntSOC
Paul B avatar image
Paul B answered ·
Have a look at this link as that may help you https://octopusasia.com/battery-monitor-and-soc-state-of-charge/
Grant Baldock avatar image Grant Baldock commented ·
Thank you Paul,
I watched the video and whilst I believe that I may need to alter some of the settings so that when I am off-grid and using Solar that I don't move to 100% too early. It doesn't appear to explain why I am not hitting the automatic 100% SOC when on 240v charge.
Cheers
Paul B avatar image Paul B Grant Baldock commented ·
More than likley the charged voltage setting, you need to read up on all those different settings
