stanhausc avatar image
stanhausc asked
How to open setting values in Venus OS interface?
I'm trying to configure the interface of a Venus GX and also a CCGX, the idea is for the user to be able to set the values de Charge Voltage Limit (CVL), Charge Current Limit (CCL)and Discharge Current Limit (DCL), as in the image below:
I started by copying an example:
In your QML file, it looks like this:
MbSpinBox {
description: qsTr("Minimum SOC (unless grid fails)")
enabled: userHasWriteAccess
show: hub4Mode.value !== hub4Disabled && stateItem.value !== batteryKeepCharged
bind: Utils.path(batteryLifePath, "/MinimumSocLimit")
numOfDecimals: 0
unit: "%"
min: 0
max: 100
stepSize: 5
I'm at the very beginning of my studies, as you can see, and I tried as follows:
MbSpinBox {
description: qsTr("Charge Voltage Limit (CVL)")
show: valid && showSetting(0)
bind: service.path("/Info/MaxChargeVoltage")
numOfDecimals: 0
unit: "%"
min: 0
max: 100
stepSize: 0.5
Could someone please direct me to where I should go, I believe I'm missing the path of bind, show, and property that is at the beginning of the file:
property string bindPrefix
property string bindPage: "/Settings/Battery/"
property string cgwacsPath: "com.victronenergy.settings/Settings/CGwacs"
property string settingsPrefix: "com.victronenergy.settings"
property string batteryLifePath: cgwacsPath + "/BatteryLife"
// Hub4Mode
property int hub4PhaseCompensation: 1
property int hub4PhaseSplit: 2
property int hub4Disabled: 3
// BatteryLifeState
property int batteryLifeStateDisabled: 0
property int batteryLifeStateRestart: 1
property int batteryLifeStateDefault: 2
property int batteryLifeStateAbsorption: 3
property int batteryLifeStateFloat: 4
property int batteryLifeStateDischarged: 5
property int batteryLifeStateForceCharge: 6
property int batteryLifeStateSustain: 7
property int batteryLifeStateLowSocCharge: 8
property int batteryKeepCharged: 9
property int batterySocGuardDefault: 10
property int batterySocGuardDischarged: 11
property int batterySocGuardLowSocCharge: 12
property VBusItemCheckValid maxVoltageCellId: VBusItemCheckValid {
bind: Utils.path(bindPrefix, "/System/MaxVoltageCellId")
property VBusItem systemType: VBusItem { bind: "com.victronenergy.system/SystemType" }
property VBusItem gridSetpoint: VBusItem { bind: "com.victronenergy.settings/Settings/CGwacs/AcPowerSetPoint" }
property VBusItem maxChargePowerItem: VBusItem { bind: Utils.path(cgwacsPath, "/MaxChargePower") }
property VBusItem maxDischargePowerItem: VBusItem { bind: Utils.path(cgwacsPath, "/MaxDischargePower") }
property VBusItem socLimitItem: VBusItem { bind: Utils.path(batteryLifePath, "/SocLimit") }
property VBusItem minSocLimitItem: VBusItem { bind: Utils.path(batteryLifePath, "/MinimumSocLimit") }
property VBusItem stateItem: VBusItem { bind: Utils.path(batteryLifePath, "/State") }
property VBusItem hub4Mode: VBusItem { bind: Utils.path(cgwacsPath, "/Hub4Mode") }
property VBusItem maxChargeCurrentControl: VBusItem { bind: "com.victronenergy.system/Control/MaxChargeCurrent" }
property bool locked: lock.valid && lock.value
// Hub4Mode
// BatteryLifeState
Does anyone have any idea how I should proceed, or where do I find information about it?
Thank you!
Venus OSmodifications
markus avatar image
markus answered ·
Hi @stanhausc
You can override the the CVL in DVCC menu. There you can set a charging amps limit too.
BR.
Markus
markus avatar image markus ♦♦ commented ·
The values in your screenshot are the parameters your battery sends to the system via CANbus.
stanhausc answered ·
Hi @Markus, thanks for the answer.
For your tip, I created a new interface, with CCL and CVL, as in the image below.
However, it did not work for DCl, See the QML:
import QtQuick 1.1
import "utils.js" as Utils
MbPage {
property VBusItem maxChargeCurrent: VBusItem {bind: Utils.path("com.victronenergy.settings", "/Settings/SystemSetup/MaxChargeCurrent")}
property VBusItem maxChargeVoltage: VBusItem {bind: Utils.path("com.victronenergy.settings", "/Settings/SystemSetup/MaxChargeVoltage")}
property VBusItem maxDischargeVoltage: VBusItem {bind: Utils.path("com.victronenergy.settings", "/Settings/SystemSetup/MaxDischargeCurrent")}
Component {
MbOption {}
model: VisualItemModel {
MbItemText {
text: qsTr("<b>CUIDADO:</b> Leia o manual antes de ajustar")
wrapMode: Text.WordWrap
horizontalAlignment: Text.AlignLeft
show: dvccSwitch.userHasWriteAccess
MbSwitch {
function edit() {
maxChargeCurrent.setValue(maxChargeCurrent.value < 0 ? 50 : -1)
name: qsTr("Charge Current Limit (CCL)")
checked: maxChargeCurrent.value >= 0
show: dvccSwitch.checked
MbSpinBox {
description: qsTr("Charge Current Limit (CCL)")
bind: maxChargeCurrent.bind
unit: "A"
numOfDecimals: 0
stepSize: 1
min: 0
show: maxChargeCurrentSwitch.show && maxChargeCurrentSwitch.checked
MbSwitch {
function edit() {
maxDischargeCurrent.setValue(maxDischargeCurrent.value === 0 ? 50 : -1)
name: qsTr("Discharge Current Limit (DCL)")
checked: maxDischargeCurrent.value >= 0
MbSpinBox {
description: qsTr("Discharge Current Limit (DCL)")
bind: maxDischargeCurrent.bind
unit: "A"
numOfDecimals: 0
stepSize: 1
show: maxDischargeCurrentSwitch.show && maxDischargeCurrentSwitch.checked
MbSwitch {
function edit() {
maxChargeVoltage.setValue(maxChargeVoltage.value === 0.0 ? 55.0 : 0.0)
name: qsTr("Charge Voltage Limit (CVL)")
checked: maxChargeVoltage.value > 0
MbSpinBox {
bind: maxChargeVoltage.bind
unit: "V"
numOfDecimals: 1
stepSize: 0.1
show: maxChargeVoltageSwitch.show && maxChargeVoltageSwitch.checked
Any suggestions, why the DCL doesn't work?
If your ESS is running under „external control“ the DCL is ignored as far as I know.
I am no good programmer, so unfortunately I can’t really help you with your code.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Experiments, Modifications and Adaptions. Mods (Modifications) can be made to Victron Software by the Community. Please use the modifications space for enthusiasts who want to push what is possible, without official Victron Support.
