How am i able to mount the mppt without access to the upper mounting holes? Bracket can't be used as this will be used in a moving vehicle.
Make up a mounting plate that has a margin around the MPPT. Fix the plate to the MPPT, and then mount the MPPT and plate in the vehicle?
32 People are following this question.
