muammer avatar image
muammer asked
Can I use 150 /85 Ve.can Smartsolar MPPT with MPPT RS as a parallel ?
I have a 2 pcs 450 /200 MPPT RS on the system and ı must connect 6 more solar panel on the system. 150 / 85 Ve .can is enough for the system according to the my calculation.
I know that ı can use the the 2 different mppt on the system with cerbo. I want to be sure that find a effective way for the safety etc.
MPPT SmartSolarmppt rs
Alexandra avatar image
Alexandra answered ·
@muammer
Since they all CAN connect to the Cerbo for system communication, with DVCC you will be fine if you are referring to battery charging and taking care if thise. You would definitely be using a bus bar to connect the outputs.
But to really answer your question we would need more details about your system.
