juergen pflug avatar image
juergen pflug asked
Grafana dashboard - Ideas
Hi.
I have finally got my VICTRON-Grafana dashboard running :-)
The devices in use are:
Venus GX
Quattro 48/8000
2x SmartSolar Charger MPPT 150/85 &
BYD Battery & BMS
I am using a Raspberry Pi4 running DietPi, InfluxDB, Telegraph plugin and Grafana Server.
I also installed the following plugins on grafana:
SUN and Moon (data source)
and
Carpet Plot
It is still work in progress but I am quite happy with outcome so far.
I have created a "Overview" dashboard where basically everything should be "green" - when OK.
So a quick look should tell me that everything is OK.
2021-07-27-11-48-27-victron-vrm-grafana-mozilla-fi.pngThere are more detailed dashboards for other things like the inverter:
or Battery
2021-07-27-12-06-47-victron-vrm-grafana-mozilla-fi.pngor charger - current data & history
I borrowed some ideas from other dashboards and added some of my ideas.
This is just to give you some additional ideas for the layouts
Cheers
VRMBMV Battery Monitorgrafana
pau1phi11ips avatar image
pau1phi11ips answered ·
Looks awesome!
Hoping to do something like this at some point. Too busy converting a van to a motorhome at the mo.
Marnix Keesmaat avatar image
Marnix Keesmaat answered ·
Would you like to share the json for the Grafana dashboards?
They look very nice.
jwfrary avatar image jwfrary commented ·
@juergen pflug would be really cool if you could share the json files for your dashboards!
juergen pflug answered ·
no problem :-)
Victron VRM-1630403024735.zip
but keep in mind: this is still work in progress :-)
cheers
Awesome cheers
daba avatar image
daba answered ·
ppr avatar image ppr commented ·
would you share your approach as well and share the json?
thank you
tinyvan avatar image
tinyvan answered ·
hello - my grafana data collection works fine with the default, but not with imported json files. do i have to set other things to work that? win 10 docker - so data are there, but with json files not visible. do you have any ideas? thx!!
thiemoh avatar image
thiemoh answered ·
I transformed the awesome dashboard from juergen pflug to match the data format of default victron influx logging:
VictronDashboad.json.zip
albundy0815 avatar image albundy0815 commented ·
Hi and thanks a lot for providing the victrondashboard. I checked it on my side and most of them is working. But I've one special question which I'm not sure if you can reproduce it.
I would like to have the history yield of the solarcharger and it seems that these data are not in the influxdb. I see a lot of entries but not the history. I was searching the last days for a solution to reproduce it and it seems that these data are not requested from the docker victron-server.
and if I check it I can't get the data
When I check the measurements in influx, I can't see any measurement with the daily history:
Could you please check it for me as well? I guess, this was removed in the docker image?!
