simonvlllbr avatar image
simonvlllbr asked
How can you exchange the data from vrm portal into grafana to analyse them?
I try to get some data from vrm to grafana. Is there any conclusion to do that.
VRMVictronConnectgloballinkgrafana
matt1309 avatar image
matt1309 answered ·
Hi @simonvlllbr
If you want to get the data via VRM there's an API, this might be helpful:
VRM API documentation (victronenergy.com)
However you may be more interested in integrating this setup:
GitHub - victronenergy/venus-docker-grafana
The benefit of the method in second link is you're not relying on external cloud service. ie using VRM API the data is going:
From local Venus os/cerbo device -> VRM
Then you're taking it from VRM back to locally run grafana.
Second Link method uses:
From local VEnus os/cerbo device -> Grafana (with some extra steps in the background explained on the github page)
