molos avatar image
molos asked
MPPT 75/10 charging
e6093560-fdc2-4f87-b5a7-bd9afdd2815b.jpeg34328138-9126-444e-951a-402163e75d3b.jpegHello 5557a62c-70d4-40cb-94a6-193a5a138fbb.jpegwe have a small teardrop trailer with the MPPT 75/10 and panels, our original battery only lasted 6 months but it appears it was always showing solar watts. i am attaching 3 screenshots if someone can tell me if it looks correct. I am assuming that my battery is good now so it is mostly in float or bulk mode.
battery charging
There are many similar questions in the community, please use the search function.
You have 0V battery voltage everyday that is a sign that there is a problem with the connection between the MPPT and the battery.
Check all connection, switches and fuses between the MPPT and the battery.
