frankdg avatar image
frankdg asked
Absorption time and Lifepo4 what is the best
Hi Victron friends
Have a 180Ah Lifepo4 from CS batteries and it has a built in "active" cell balancer.
On the camper roof 1 x 140Wp on MPPT 75/10 Smart and.. 2 x 110Wp + 1 x 175Wp on MPPT100/30 Smart
Both MPPT's are set to Lifepo4 but, I read at the bottom of the battery menu that the absorption time is 2h00 and "fixed".
If I look every day in the "history" I read "absorption time = 2h00...
If I understand correctly, the Lifepo4 is kept at 14.2v for 2h00...?
So I'm looking for an answer because a Lifepo4 doesn't need "absorption time" or am I wrong?
In the meantime, I have already set that absorption time to 0, once at 10 minutes 20 and also at 30 minutes
We have a lot of consumers, Nespresso, kettle, even induction via a 2Kw inverter, so the SoC goes from 100% every evening to 70 or sometimes to 65%
I bought this Lifepo4 for the "comfort" but I also want to treat them "correctly" and then it is about the lifespan
Since 2 days I have both MPPTs set to "adaptive" absorption
"loading" the Lifepo4 cells (unnecessarily) to 14.2v for a long time by continuing to use a "fixed" absorption time does not seem to me to be conducive to the lifespan, does it?
I can also set the absorption time to 0 because I also have a Victron IP22/30 and .... I can also use it every month when I am connected to shore power
The theme of "absorption" at Lifepo4 has been mentioned so many times
And we often read differing opinions...
But, what is actually the "best" way, taking into account that we use the Lifepo4 well every day (discharged)
Thank you very much for the responses
With best regards
Frank , Antwerp Belgium
VRM
Elimac avatar image
Elimac answered ·
This is an interesting topic. I had also the same doubts. In time, I developped my current opinion:
- If you have cells that were well top-balanced, you can live almost without absorption time.
- The absorption time has 2 goals: (1) finish the last 5~10% of charging and mainly (2) give time for the equalization circuitry (that normally only works in the higher voltage band) to do its job of balancing the cells. So, if cells don't need balance, you can skip this phase. And you also avoid charging to high SOC.
- But, the threshold voltage you select bulk->Absorprtion -> float also plays an inportant role.
My current settings are:
Summer (long days): bulk up to 3.45V/ cell, 5 min Abs time, 3.35 V/ cell FLOAT
Winter: (short/cloudy days): bulk up to 3.45/cell, 30min Abs time, 3.36 v/ cell Float.
Kevin Windrem avatar image
Kevin Windrem answered ·
In reality, absorption in my system lasts far less than the preset value. Absorption ends when the absorption voltage is reached and the charge current drops to the tail threshold.
You are correct that you probably don't need to cell balance with each cycle or partial cycle. But then you need to decide when to do it.
Battle Born says that charging their batteries to 100% does not shorten their life. I can't speak to other batteries.
I believe Victron recommends fixed absorption for LFPs. I also think the absorption time is the maximum time.
frankdg answered ·
Hi Elimac & Kevin
Thanks for the feedback
What I did now 5 minutes ago is the max absorption current set from 14,2v to max. 13,8volts.
I did not change the float-current from 13,5volts it remains standard...for Lifepo4
Both MPPT-chargers were already in float-modus so, after I changed the max absorption current they started both in bulk-modus....is normal
I set the "absorption time" yesterday in "adapitive-modus" so I, must see tomorrow in the "each-day" history that this is enough for both MPPT to arrive at 13,8v max absorption-time
If not than I will set the absorption time "fixed" and max. 1h00
Until now the SoC was always 100% so, I am gonna see the coming days how much de SoC wil drop in % with the new setting of 13,8volts
My argument to set the max. absorption current to 13,8v was because the cells don't need every day to be loaded to 14,2v....
I am looking now with pleasure how the Victron engineers will react here what I described here
Regards from Belgium
Frank
nick-a avatar image
nick-a answered ·
Dear all,
What I have done is the following:
Battery voltage: 12V (LiFePO4)
Max charge current 20A (I use a smart MPPT 100/20). I could set a bit lower.
Expert mode on
Charge voltages:
Absorption voltage set to 14.10 Volts. (that is 3.525V per cell and is a bit on the high side 14.00 would be better)
Float at 13.70V (we do not need to float these Litium Iron Phosphate batteries)
Equ voltage greyed out
Bulk:
Re-bulk offset 0.20V (is maybe a bit too low - just testing for the moment)
Absorption:
Duration 5 minutes (could be lower - just testing it while monitoring each cell in the BMS)
Tail current: disabled
equalization stop mode: fixed time
Eq duration: 0 minutes
Voltage compensation:
Temperature compensation disabled
The BMS controller is a bit more complex but I use my cells between max 3.60V and 3.00 V. Which relates to the steep inflection points in the IU curve and the state of charge (SOC) is then somewhere between 95% and 5%.
I use an Overkill BMS also known as LLT power or JBD type bms.
4S LiFePO4/120A bms with bluetooth. I have it for only one week and it works with Android and my iPad. I still have to tests it with an uart.
Base parameters:
Cell number: 4
Nominal capacity: 75 Ah
Galvanometer resistance: 0.20 milliOhm
Protection params:
Overvoltage: 3.60 Volts (V from now on)
Overvoltage release 3.45V
Overvoltage release delay 2.0 seconds (s from now on)
Undervoltage: 3.00V
Undervoltage release 3.25V
Undervoltage release delay 2s
Pack undervoltage 12.00V
Pack undervoltage release 13.00 V
Pack undervoltage release delay 2s.
Charging over temperature: 50 degrees Celcius (C from now on)
Charging over temp release 40C.
Charging over temp delay: 2s.
Charging under temp 5C
Charging under temp release 7C
Chargeing under temp delay 2s
Discharge over temperature: 50C
Discharge over temp release: 45C
Discharge over temp release delay 2s
Discharge under temperature -10C
Discharge under temp release 0C
Discharge under temp delay 2s
Charge over current 40 Ampere (A from now on)
Charge overcurrent release 32A
Charge overcurrent release delay 10s
Discharge overcurrent 60A
Discharge overcurrent release 32A
Discharge overcurrent delay 10s
Balance turn-on voltage: 3.20V
Balance precision 0.001V
Hardware protection:
hardware overcurrent protection 67A @ 160 milliseconds
hardware short circuit protection 89A@ 70 microseconds
short-circuit protection release delay 32s
Hardware overvoltage protection 3.70V
Hardware overvoltage protection delay 8s
hardware undervoltage protection 2.70V
Hardware undervoltage delay 16s
Small lecture point (I could not resist after reading one of the answers)
Electrical current does not have the unit of volts. Electrical potential differences (U) do have the unit of Volt (V). Electrical currents (I) have a unit of Amperes (A).
nick-a avatar image
nick-a answered ·
frankdg answered ·
img-5980.jpgDear all
I checked this morning the history
The absorption-time is still in "adaptive" mode
The max absorption-current is 13,83v so that seems better for de cells than keep the cells every day for a certain time up to 14,2v
Maybe I increase also the float-current up to 13,6volts to keep the "gap" between max absorption-current from 13,8volts and the float-current (now 13,5volts) a little shorter
When the both MPPT's starts more often in bulk-modus the max absorption current will never rise above the 13,8volts
To keep the cells in a good balance I will start every month the IP22/30 and charge the Lifepo4 up to 14,2v (for that I added an automatic message in my iPhone agenda)
Best Regards from Belgium
Frank
seb71 avatar image
seb71 answered ·
For charging LiFePO4, ideally you have 2 + 1 stages:
  • Charging from empty with a constant current - such as 0.5C - (if possible to maintain a constant current), until a certain cell/battery voltage is reached (this voltage is the one which you set as "absorption voltage"). This stage is referenced as "Bulk". This voltage should not be set greater than 3.6V (cell voltage). It can be set lower, such as 3.55V, 3.50V, even 3.45V (depending on the actual cells used and the BMS - if any).
  • Then you maintain a constant voltage (the one set as "Absorption voltage") and continue charging. Because the voltage is kept more or less at a fixed and limited value, the current the battery absorbs will naturally drop over time. This is also referred as the "Absorption" stage. This would be best ended using the "Tail current" setting (when this setting is available). For instance the constant voltage stage (absorption stage) will be ended when the current taken by the battery drops under 0.05C (this means 5A for a 100Ah cell). If the tail current is not available to be set, you use a time limit (chosen based on manually monitoring the constant voltage stage - you check how much time it takes to the current to drop to that "tail current" limit you would want).
  • After ending the constant voltage stage, you just want to keep the fully charged battery at its "natural equilibrium voltage"© (name made up by me), which is around 3.35V (cell voltage). This would be the "Float" stage. No charging takes place anymore (more or less), but you want to also avoid discharging (if you still have solar power from the PV panels to power the loads). By maintaining this "Float" voltage, the loads should be powered directly by the PV panels, keeping the battery fully charged for when the Sun goes down.
In practice you can't always follow this algorithm. For instance, when you have cloudy weather, the charging current during constant voltage stage/absorption can drop at a value lower than the "Tail current" value not because the battery can't take higher current, but because the PV power production drops due to the clouds. So some adjustments of the settings (those settings related to the end of constant voltage/absorption stage) are usually required.
Regarding discharging - you should avoid dropping under 3.0V (cell voltage). This limit can be set higher, but do not set it lower.
frankdg answered ·
Dear all,
Since my last reaction I used again the standard settings for Lifepo4 in both MPPT's
My Victron supplier advised me select the settings for Lifepo4 without make any changes .
The MPPT settings for Lifepo4 are developed bij Victron.
In the standard setting for Lifepo4 the absorption-time is "fixed" for 2h00
But during this 2 hours the current is very low and the voltage stays never higher than 14,20v
My question is shall I use the adaptive absorption for Lifepo4 ?
I think is more useful for lead-acid Gel of AGM battery....?
I buyed a 180Ah Lifepo4 to have more comfort in my motorhome
Nespresso 4 x a day , a 650watt water kettle, a 850watt toaster an even a induction plate that I starting up max on 1400watt and I use the plate only when we have enough sun on the 535Wp solar panels
Continously and directly plugged in on the 12V supply : 2 iPad's ,2 iPhone's a Mac-book Air, a 16 liter compressor cooling box
I have also Ctek MXS 10 charger (also continuously) plugged in a 350/700 Phoenix inverter...to keep the 90Ah starter battery all the time in float-modus between 13,5 and 13,6v
But I am considering to buy & install a Victron Orion 12/12/9 adjusted to max. 13,6v for the starter battery
So, I use my 180Ah Lifepo4 every day but I keep my eye also on the app of the Smart Shunt
The best investment ever..
Regards
Frank
frankdg answered ·
Dear all
Many thanks for all the reactions
Before I start a new topic about Lifepo4 and absorption-time..
I mentioned also in my previous reactions that I use also a Victron IP22/30.
And I selected since i use this charger the Lifepo settings no more no less
Until now I did not searching further in the IP22 menu , but I found today also the possibility to reduce the absorption-time for max 1 hour instead to use the standard 2 hours for Lifepo .
What shallI do?.....use the standard selection for Lifepo4 of shall I change the settings by using "user defining" and reduce the absorption time to max. 1 hour
What I further see in the menu is that de reconditioning is 'switched off" so that is ok
But down below I can not set the de reconditioning-time to zero..?
It seems logical when the reconditioning is "switched off" that the recond-time down below must be also come to zero...
A time from 15 min will stays visible even when the reconditioning-time is "switched-off"
