Is this firmware safe to install?
@Alexandra I guess he is referring to the VE.Bus smart dongle that had a bug in version 1.10 and was rolled back to 1.09.
@s_signor@bellsouth.net I can't test it right now but I don't think the same will happen twice in a row.
https://www.victronenergy.com/live/victronconnect:beta
VE.Bus Smart Dongle:
Add firmware to v1.11: (mandatory update upon connection)
- Fixed constant connection reset bug, introduced in V1.10, between dongle and inverter on MultiPlus/Quattro firmware versions before xxxx460
- Fixed MultiPlus/Quattro status briefly indicated FAULT immediately after firmware update or power cycle
- Add dongle status feedback during initialization and mode switch between secondary and primary mode.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
28 People are following this question.
