Li'l help! I have a MPPT charge controller 150\100 (bluetooth) and what i've been told is i can run 24volt panel (350w) to 12volt gel batteries, And the charge controller will regulate it.. is this true before i install?. Thanks for your time!
Yes this is true. The 150/100 can take an input of up to 150 volts with an output of up to100 amps at a rang of voltages from 12 to 48 volts. This would be more than sufficient for a 350 watt panel which at 12 volts (mppt output voltage) would produce approximately 30 amps. The system could be extended to have up to three panels before maxing out the mppt.
43 People are following this question.
