andi-hp avatar image
andi-hp asked
Can't change the PIN of my BSC IP22
Now my setup is working for several weeks and I want to secure the setting an change the orginal PIN 000000 to a secret one, but when I go in the Menu to chnage the PIN Code, I always get the message that the old pincode is incorrect, but I never changed it and the connection works propperly.
What is wrong?
Thank you
Best regards
Andreas
Bluetooth
Try to reset the PIN to default with the PUK.
The PUK can be found on the sticker on the back of the charger.
