This is from my RV's system. It looks like the PV voltage is too low to charge? Is that normal? My RV battery is 12V, why is it showing up 20V+?
Maybe you mixed up the connection on the smartsolar ... maybe you connected the PV to the battery termimal of the smartsolar and the battery to the PV terminal of the smartsolar
Would the charger recognize that? I haven't modified the connections. It came from the RV.
As others have stated, it appears that your connections are incorrect.
Has this system worked previously or is this a new installation?
If it has worked previously and hasn't had any changes made to it, then I would be inclined to think that there is a bug in the software.
If it is a new installation then I would definitely check your wiring.
In either case, if you are able to take voltage measurements at the terminals on the SmartSolar we would be able to confirm the issue.
31 People are following this question.
