denzel avatar image
denzel asked
Parallel Multi question
Im planning upgrading to a parallel system. 2 multiplus 3000/24/70 (Gen 1) . I can confirm the following:
Both units are identical
Both units have the same firmware
Relevant VE config changes will be done when needed
Connected to the primary unit currently is a 150/70 MPPT and a 24v Battery + Venus GX and BMV.
i understand the DC cables must be of same lengths and gauge (DC bus will be used)
My questions :
Can i bridge the AC input feed to from the Inverter 1 to power inverter 2?
Can i bridge the AC output feed to inverter 1 to power the loads ?
Does AC output 2 still work independent or does it also have to be bridged ?
Regards
multiplus in parallel
