jasontav avatar image
jasontav asked
SmartLithium Balancing issue
I have a pair of SmartLithium 12V/150Ah in series for a 24V battery. Both on v1.24 firmware.
One of the seems to be having a problem balancing. The other one is fine.
This is from the end of a 2hr absorption phase - you can see cell 3 is really lagging behind:
any ideas?
Lithium BatteryBMS
Paul B avatar image
Paul B answered ·
Its not far out 0.04 volts is a small diferance and not enough to really worry about the bms will correct it over the next few weeks
or just keep it charging at 28.0 volts untill that cell comes up.
jasontav answered ·
perhaps I should have mentioned, normally the batteries balance in about 30 minutes, so this is unusual/changed behaviour.
Also, that cell have been stuck at 3.48V/3.49V for about an 1.5hrs now. Normally I see voltage changes between cells fairly quickly,
The very first charging can take a few hours.
jasontav avatar image jasontav commented ·
this isn't a first charge - I've had the batteries approx 2 years
klim8skeptic avatar image
klim8skeptic answered ·
Are you still balancing your batteries for 4-8 hours of absorption each month?
Battery Balancing..
recently i have been doing 30 minutes a week and both batteries have balanced in that time.
because they hadn't this week I initiated a manual equalisation from the controllers (NOTE: I have equalisation set up for my weekly full charges/balances) and then saw the behaviour from the screenshot
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
