moorhs avatar image
moorhs asked
3-Phase Air Conditioner of 3xQuattros
I'm looking into adding a microgrid to my house (3-Phase Wye) and considering using 3 Quattros but the manual says "Note: the Quattro is not suitable for 3-phase delta (Δ) configuration.".
Although the house is wired as 3-phase Wye I have a Daikin 3-phase AC installed and it's motor is Wye-Start-Delta-Run so my question is will the 3 Quattros in 3-Phase mode support this load or not? The AC's external wiring is Wye 3+N and the conversion to delta is done inside the unit.
Thanks for the help
MultiPlus Quattro Inverter Charger3 phase
Paul B avatar image
Paul B answered ·
The units will work that way.
its only if the mains/generator was connected in delta format that there is a issue
moorhs avatar image
moorhs answered ·
Thanks Paul :)
