Simon Grover avatar image
Simon Grover asked
correct setup for CANBAT LiFePO4 12V SYSTEM - with 800w solar in series
Hi all.
so the battery runs my pc and other things fine. some days the battery is hardly used. hasn't gone below 13 volts. o sunny days the 80amp breaker will trip. Looking at the history shows the battery hitting 16.26v I have manual entered the info and though I had fixed the issue until i was running my pc and slow cooker on the same day. any help will be much appreciated
210197746_869847330280470_2704451287182491519_n.png210219411_211998237490592_985787188095651621_n.png210473117_197552352292721_1693202891917737498_n.png
Lithium Battery
klim8skeptic avatar image
klim8skeptic answered ·
It would seem that the 80a breaker is tripping, causing a brief voltage spike on the output of the mppt.
Solution is probably to use a better quality breaker.
Simon Grover avatar image Simon Grover commented ·
ok thank you. I was thinking it might have been the BMS fighting with the controller. I was able to catch the trip on the graphs. would you still say this was still due to faulty breakers. most of the time its the breaker on the + wire and rarely on the - wireCapture.JPG211531950_230552442250274_698871380014170325_n.png214633741_583741129280064_8504825213536904627_n.png
