adventurebumss avatar image
adventurebumss asked
victron 12-12 30 amp non isolated charger
hello everyone I have two victron 12-12 30 amps chargers wired in parallel with fuses on the input and output. when I start the van they b both turn on then after about 2 mins one turners off because no detection of engine. the other will stay in bulk charge for about a minute then turn off then turn back on for a minute. I don't know if the problem is my alternator is to small or faulty victron product
battery charging
You have to look at the input voltage, if it goes below the configured threshold the Orion will stop charging.
adventurebumss avatar image adventurebumss commented ·
So if that's the case it would be the alternator is to small to push 60 amps correct?
adventurebumss answered ·
