dnnypck avatar image
dnnypck asked
Can I set a MultiPlus 3000 current limit with the BMV-712 wall panel?
I usually do this using the Victron phone app, and adjusting the VE Bus current limit controls directly, but since a firmware bug is currently preventing this, I wonder if anyone knows if I am able to use the BMV-712 wall panel to change this setting? It's currently limited to 7.7 amps, for some reason, so even though I'm plugged in to a 30 amp outlet, i'm slowly losing battery life.
BMV Battery Monitorinverter current draw
Paul B avatar image
Paul B answered ·
No you cant change that setting or any setting in a Multiplus by using the BMV units.
or you can adjust it using a laptop and a MK3 unit. or a Cerbo GX unit connected to the VE bus
Jesse avatar image
Jesse answered ·
Pretty sure that's not possible.
If you have the ability to connect it to your laptop you can install an assistant that lets you make a charge current adjustor knob yourself using minimal components. But then you'd also be able to set the current directly that way...
Victron BMV battery monitors product page
