aedanc avatar image
Can't Zero a BMV600S
I have a BMV600S that reads -1.5A when there is no current flowing through the shunt, as verified by two ammeters. I have tried the Zeroing procedure but it makes no difference. I understand that I should select Zero in the setup, then press the setup button for 3 seconds and I should get a response saying "ok". I don't get the "ok", it just goes straight out of setup. Any ideas?
Thanks,
Aedan
BMV Battery Monitor
Hi @AedanC
I think you have to press the 'select' button, not the 'setup' button.
aedanc avatar image
aedanc answered ·
Thank you very much Daniel, that worked perfectly. I promise I'll read the manual more carefully next time!
Aedan
