Hello all, does anyone else also have the problem that the I/O menu is no longer displayed, for example, not used inputs of the Victron GX Tank 140 to turn off? Does anyone know a solution?
BR RZ
HA! You discovered a bug. The I/O menu appears only if analog or digital inputs are found, BUT the test for analog input is based on analog tank inputs. Since there aren't any and you probably haven't set up any digital inputs, the I/O menu won't appear.
The code should check for GX Tank inputs and probably temperature inputs too.
You can work around this by installing my RpiGipoSetup package which will activate the PI's 5 digital inputs.
https://github.com/kwindrem/RpiGpioSetup
The code that looks for analog and digital inputs is based on persistent settings so you can even uninstall the package and the I/O menu will remain visible.
The GX Tank shows up on my RPI 4 in both v2.71 and v2.72~2.
Without it plugged in, I have an I/O menu but the analog section is empty as you'd expect with no analog inputs.
BTW, I have enabled all 5 digital inputs per info from Rob D.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
35 People are following this question.
