Hello, As the title says, how do I use VEConfigure 3 to view ripple. Whenever I connect to the Quattro over VEConfigure 3 the load is turned off.
This is taken from Victron Unlimited:
Cheers
Cheers
Hi, are you saying the load is intentionally off when you are connected to VE Configure? Could you elaborate? Normally you can see the Ripple reading when the Quattro is running and you are connected using the MK3 USB interface.
47 People are following this question.
