Hi All, new to this. I need to upgrade my existing firmware 2609154. What is the most stable version and can I upgrade straight to this or do I need to upgrade in steps?
Thanks in advance
Cheers
Thanks in advance
Cheers
You need to take the "old" way via VE.flash.
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
You can directly update to the latest version for your device.
In you case 2609482.
First 4 numbers are the hardware ID and the last 3 the FW version.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
28 People are following this question.
